[gdal-dev] Building GDAL documentation with ReadTheDocs
Javier Jimenez Shaw j1 at jimenezshaw.com
Wed Jul 24 03:33:43 PDT 2024
I see the point, and I agree... but I don't know if it will work
RTD redirects to whatever we configure. In proj.org it is going directly to
9.4 (current latest release).
So every 6 months it points to something different. Telling in robots.txt
that the full page has a different URL is not good for seo and history (if
I understand correctly how it works, that I am not sure).
Maybe the solution is that proj.org default be "stable" and not "9.4".
On Wed, 24 Jul 2024, 11:11 Robert Coup via gdal-dev, <
gdal-dev at lists.osgeo.org> wrote:
> Hi Dan,
> On Tue, 23 Jul 2024 at 17:16, Daniel Baston via gdal-dev <
>> If anyone has feedback about using ReadTheDocs for this project, or
>> the specifics of the proposed configuration, please share it here or
>> as a comment on the pull request.
> My only suggestion would be to check/ensure that non-latest-version docs
> are "no-indexed" for search crawlers, either via /robots.txt, headers or
> meta tags. I don't know if it's a RTD setting these days, but it's really
> frustrating to land on historic doc versions from a search engine without
> realising. For example, PostgreSQL has been historically awful for this,
> but I think it's better now (not that they use RTD).
> Rob :)
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240724/114ac34c/attachment.htm>
