[gdal-dev] Building GDAL documentation with ReadTheDocs
Robert Coup robert.coup at koordinates.com
Wed Jul 24 04:43:55 PDT 2024
On Wed, 24 Jul 2024 at 12:27, Even Rouault <even.rouault at spatialys.com>
wrote:
> Le 24/07/2024 à 12:33, Javier Jimenez Shaw via gdal-dev a écrit :
>> I see the point, and I agree... but I don't know if it will work
>> RTD redirects to whatever we configure. In proj.org it is going directly
to 9.4 (current latest release).
> Seems like a good idea and something that can be easily be tuned by
editing https://readthedocs.org/dashboard/osgeo-proj/edit/ . But when
looking at https://proj.org/en/stable/about.html for example, the only
thing that is missing to me is a hint of what "stable" alias to. So you
have on the top left, under the PROJ logo, a "stable" text. It would be
nice if that would be "stable (9.4)". Not sure if that can be tuned.
> So every 6 months it points to something different. Telling in robots.txt
that the full page has a different URL is not good for seo and history (if
I understand correctly how it works, that I am not sure).
I think using `/en/stable/` (or /latest) as the default URL redirect is the
thing — as a new release gets promoted, google/etc will keep using/crawling
that, and that link doesn't change.
I think the robots thing would need something a bit like:
allow: /en/stable/
disallow: /en/
Though in principle, no-index would be preferable to "do not crawl". Not
sure what levers RTD has in that regard, if /stable/ and /9.4/ are actually
different sets of html files then adding in an HTML <meta> tag for noindex
might be simple enough for !=stable ?
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240724/e86a3eb2/attachment.htm>
