[gdal-dev] dealing with complex (a+ib) images
Daniel Evans
daniel.fred.evans at gmail.com
Sat Jul 27 04:49:49 PDT 2024
I would presume that Javier is intending to use one of the several Complex
data types that GDAL supports natively - CInt16, CInt32, CFloat32, CFloat64.
It seems that VRTs appear to have the capability to create a complex band
from two separate bands, and vice versa - the "complex", "imag", and "real"
pixel functions for "Derived Bands":
https://gdal.org/drivers/raster/vrt.html#default-pixel-functions
Cheers,
Daniel
On Sat, 27 Jul 2024 at 12:35, Greg Troxel via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org> writes:
> > I have to create a complex number (real and imaginary part) image out of
> > two "normal" images or bands.
> > How can I do it?
> I don't know, but it would be great if you explained what that means.
> I did a quick web search and didn't find anything.
> There is multispectral where there are N pixel values for each x/y
> position, like RGB or many more bands. But I am almost certain you
> don't mean that.
> Complex implies a magnitude and phase of a return signal and this makes
> me think about LIDAR, except the wavelength is tiny compared to features
> and ambiguity resolution seems infeasible.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240727/ec157ce1/attachment.htm>
