[gdal-dev] Band Initialization
Even Rouault
even.rouault at spatialys.com
Mon Jul 29 09:44:23 PDT 2024
Andrew,
> Is a newly created raster band initialized to zero? If not, is there
> some trivial way to perform such an initialization (this is a MEM
> driver raster, if that matters).
This might be indeed driver dependent. Drivers will generally initialize
to zero or the nodata value. As far as I can see, the MEM driver uses
calloc() to initialize the buffer, so that should be zero. Otherwise you
can use GDALRasterBand::Fill() to initialize at the value of your choice
Even
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240729/f12fb67d/attachment.htm>
