[gdal-dev] pixel class
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed Jul 31 01:19:17 PDT 2024
Hi
I am working in an algorithm that uses a lot of pixel positions both as int
and double, offset of pixels, etc.
Is there any class that avoids me to use a variable for the x and another
for the y... for everything? It would make the code much simpler.
Something where I can multiply by a factor (all the components), or sum
another pixel (as an offset), and so on. Of course, set and get each
component.
I have used in other projects Eigen::Vector2i and Vector2d. I do not mean
that we add Eigen3 as a dependency for such a minor thing, but maybe we
have already something similar.
Also I do not want to use it in any API. Just an internal tool to make code
easier to read.
Thanks.
Javier
.___ ._ ..._ .. . ._. .___ .. __ . _. . __.. ... .... ._ .__
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240731/418f37b0/attachment.htm>
