[gdal-dev] pre-commit hook failure
Even Rouault
even.rouault at spatialys.com
Fri Jun 7 10:49:52 PDT 2024
Andrew,
https://stackoverflow.com/questions/75591296/entrypoints-object-has-no-attribute-get-during-running-pre-commit
would suggest that we should perhaps update the flake8 version in
.pre-commit-config.yaml at the root of the GDAL source tree.
Can you give a try to https://github.com/OSGeo/gdal/pull/10163 ?
Even
Le 07/06/2024 à 19:36, Andrew Bell via gdal-dev a écrit :
> Hi,
> I'm getting an error when flake8 runs as a pre-commit hook and it
> won't allow me to commit code. My understanding was that the
> pre-commit stuff was supposed to make sure the proper versions were
> found. Ideas?
> (gdal) [viewshed-oor] $ git commit
> black....................................................................Passed
> isort....................................................................Passed
> flake8...................................................................Failed
> - hook id: flake8
> - exit code: 1
> Traceback (most recent call last):
> File
> "/Users/abell/.cache/pre-commit/repowsfp6jbc/py_env-python3.12/bin/flake8",
> line 8, in <module>
> sys.exit(main())
> File
> "/Users/abell/.cache/pre-commit/repowsfp6jbc/py_env-python3.12/lib/python3.12/site-packages/flake8/main/cli.py",
> line 22, in main
> app.run(argv)
> File
> "/Users/abell/.cache/pre-commit/repowsfp6jbc/py_env-python3.12/lib/python3.12/site-packages/flake8/main/application.py",
> line 363, in run
> self._run(argv)
> File
> line 350, in _run
> self.initialize(argv)
> File
> line 330, in initialize
> self.find_plugins(config_finder)
> File
> line 153, in find_plugins
> self.check_plugins = plugin_manager.Checkers(local_plugins.extension)
> File
> "/Users/abell/.cache/pre-commit/repowsfp6jbc/py_env-python3.12/lib/python3.12/site-packages/flake8/plugins/manager.py",
> line 356, in __init__
> self.manager = PluginManager(
> File
> line 238, in __init__
> self._load_entrypoint_plugins()
> File
> line 254, in _load_entrypoint_plugins
> eps = importlib_metadata.entry_points().get(self.namespace, ())
> AttributeError: 'EntryPoints' object has no attribute 'get'
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240607/f552c77c/attachment.htm>
