[gdal-dev] Changing many features in a GPKG in a transaction, why is the index updated?
Even Rouault even.rouault at spatialys.com
Tue Jun 11 18:54:15 PDT 2024
Hi Nyall,
What you observe is fully expected. The spatial index must be kept fully
in sync with the changes in the feature table, even when run within a
transaction. Otherwise if during the transaction you would execute a
spatial query, you would get inconsistents result if the spatial index
wasn't updated. And even if doing only updates, I don't think there
would really be a way to optimize updating the RTree for several
geometries at once, at least not with what is available now in SQLite.
When creating a new table and inserting features, we have an
optimization to delay (actually build in parallel) the spatial index,
but such an optimization is really restricted to that particular use
case. Updates are more complicated.
But... as you mention "bulk attribute changes", assuming you don't
change geometries, you would be better using OGR_L_UpdateFeature() where
you could specify to update only a subset of attributes instead of
updating the whole feature. In that case, the RTree triggers would not
run. That said even if the update RTree trigger runs, it checks that the
geometry hasn't changed, so as you mention rtreeUpdate running, I
suspect you change the geometries as well, in which case I have no
suggestion.
Even
Le 12/06/2024 à 03:30, Nyall Dawson via gdal-dev a écrit :
> Hi list,
> I'm trying to understand some unexpected behavior I'm seeing while
> profiling bulk attribute changes in a GPKG file.
> First, I start a transaction on the layer using
> OGR_L_StartTransaction. This is successful.
> I then make many calls to OGR_L_SetFeature, changing different
> features, before finalizing the transaction with OGR_L_CommitTransaction.
> Now, when profiling this code, I'm seeing that
> OGRGeoPackageTableLayer::ISetFeature(OGRFeature*) is taking a very
> large chunk of time. This is due to the call to sqlite3_step at
> https://github.com/OSGeo/gdal/blob/2b94d7a274bfeb881a176016de932ba8acd1b79a/ogr/ogrsf_frmts/gpkg/ogrgeopackagetablelayer.cpp#L3134
> triggering a call to rtreeUpdate within sqlite3.
> I'm confused as to why this is happening. If I'm in a transaction,
> shouldn't the index update be deferred until the transaction is
> committed? Why would it be updating after every individual update?
> Hoping someone can explain what I'm missing here...
> Nyall
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
