[gdal-dev] Getting GETBlockRef error
Raghav Singh
raghav.singh at eagleview.com
Sun Jun 16 23:42:15 PDT 2024
Hi everyone,
I am running into an issue with a wms imagery when I am running that in my local with latest mapserver-8.0.1 and gdal version with this temp configurations -
<GDAL_WMS>
<Service name="TMS">
<ServerUrl>http://{serverURL}/tile?tileRow=${y}&tileColumn=${x}&zoomLevel=${z}&minZoom=7&maxZoom=22</ServerUrl>
</Service>
<DataWindow>
<UpperLeftX>-20037508.34</UpperLeftX>
<UpperLeftY>20037508.34</UpperLeftY>
<LowerRightX>20037508.34</LowerRightX>
<LowerRightY>-20037508.34</LowerRightY>
<TileLevel>21</TileLevel>
<TileCountX>1</TileCountX>
<TileCountY>1</TileCountY>
<YOrigin>bottom</YOrigin>
</DataWindow>
<Projection>EPSG:3857</Projection>
<BlockSizeX>256</BlockSizeX>
<BlockSizeY>256</BlockSizeY>
<BandsCount>3</BandsCount>
<Timeout>60</Timeout>
<MaxConnections>4</MaxConnections>
<ZeroBlockHttpCodes>204,404,500</ZeroBlockHttpCodes>
<ZeroBlockOnServerException>true</ZeroBlockOnServerException>
</GDAL_WMS>
all my calls are running fine and I am getting the wms imagery. But when I am running this in my application which is actually using mapserver version 6.4.1 I am getting this error -
<ServiceExceptionReport xmlns="http://www.opengis.net/ogc" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.3.0" xsi:schemaLocation="http://www.opengis.net/ogc http://schemas.opengis.net/wms/1.3.0/exceptions_1_3_0.xsd">
<ServiceException> msDrawMap(): Image handling error. Failed to draw layer named 'PICT-TXXTXR24-y70fWdrEKM'. drawGDAL(): Unable to access file. GDALDatasetRasterIO() failed: GetBlockRef failed at X block offset 999552, Y block offset 1684413 </ServiceException>
</ServiceExceptionReport>
Any idea?
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240617/8f02ce4d/attachment.htm>
