[gdal-dev] GDAL 3.9.1 RC2 is available, and motion to approve it
Javier Jimenez Shaw
j1 at jimenezshaw.com
Mon Jun 24 08:14:45 PDT 2024
+1 Javier
On Mon, 24 Jun 2024 at 17:09, Howard Butler via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> +1
> Howard
> On Jun 24, 2024, at 9:46 AM, Tamas Szekeres via gdal-dev <
> +1
> Tamas
> Even Rouault via gdal-dev <gdal-dev at lists.osgeo.org> ezt írta (időpont:
> 2024. jún. 23., V, 0:13):
>> I've issued a 2nd release candidate for 3.9.1 with the following
>> additional fixes:
>> - GDALSieveFilter(): avoid assert() when all pixels are masked (3.9.0
>> regression)
>> (raster/rasterio#3101)
>> - Overview generation: fix multi-threaded bug, resulting in
>> locks/crashes with
>> GeoPackage in particular (#10245)
>> - VRT: fix serialization of separatable kernel in
>> VRTKernelFilteredSource (#10253)
>> - Zarr: SerializeNumericNoData(): use CPLJSonObject::Add(uint64_t) to
>> avoid potential
>> undefined behavior casts
>> - OGR SQL: fix crash when the ON expression of a JOIN contains OGR special
>> fields (in particular feature id)
>> - OGR layer algebra: honour PROMOTE_TO_MULTI=YES for Points
>> - OGRFeature::SetField(int, double): avoid UndefinedBehavior when
>> passing NaN
>> - OGRFeature::SetField(int, GIntBig): avoid UndefinedBehavior when
>> passing value
>> close to INT64_MAX
>> - OGRLayer::WriteArrowBatch(): avoid UndefinedBehavior when trying to
>> convert
>> NaN to Int64
>> - GeoParquet: always write version=1.1.0
>> - SQLite/GPKG: detect UNIQUE constraints expressed as a ', CONSTRAINT
>> name UNIQUE (column_name)'
>> at the end of CREATE TABLE (qgis/QGIS#57823)
>> - GDALRasterBand::ComputeStatistics(): fix bad progress percentage
>> computation (3.9.1rc1 regression)
>> - OGRSpatialReference::importFromUSGS(): avoid out-of-bounds access to
>> array (3.9.1rc1 regression)
>> Pick up an archive among the following ones (by ascending size):
>> https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.xz
>> https://download.osgeo.org/gdal/3.9.1/gdal-3.9.1rc2.tar.gz
>> https://download.osgeo.org/gdal/3.9.1/gdal391rc2.zip
>> A snapshot of the gdalautotest suite is also available:
>> https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.tar.gz
>> https://download.osgeo.org/gdal/3.9.1/gdalautotest-3.9.1rc2.zip
>> The NEWS file is here:
>> https://github.com/OSGeo/gdal/blob/v3.9.1RC2/NEWS.md
>> Even
>> http://www.spatialys.com
>> My software is free, but my time generally not.
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240624/10441b6d/attachment.htm>
