[gdal-dev] testclosedondestroydm.test
Even Rouault even.rouault at spatialys.com
Tue Jun 25 07:32:20 PDT 2024
Le 25/06/2024 à 16:25, Andrew C Aitchison a écrit :
> On Tue, 25 Jun 2024, Even Rouault via gdal-dev wrote:
>> Can you run "gdb autotest/cpp/testclosedondestroydm" , "run" , and
>> when it crashed "bt" so we have a backtrace of where it crashes  (all
>> of that after running "source ../scripts/setdevenv.sh")
> It doesn't crash:
Ah, the gtest framework must catch the exception. OK, so after starting
gdb and before "run", type "catch throw", so that debugger stops when
the exception is thrown, and then "bt"
> I do not have the MrSID SDK, so not recognizing mercator.sid is expected.
yes, a number of error messages in that test are expected depending on
which drivers are there / not there, and will not make it fail. The
FAILED you get is related to a unexpected C++ exception
http://www.spatialys.com
