[gdal-dev] testclosedondestroydm.test
Even Rouault
even.rouault at spatialys.com
Tue Jun 25 07:58:48 PDT 2024
Le 25/06/2024 à 16:52, Andrew C Aitchison a écrit :
> On Tue, 25 Jun 2024, Even Rouault wrote:
>> Le 25/06/2024 à 16:25, Andrew C Aitchison a écrit :
>>> On Tue, 25 Jun 2024, Even Rouault via gdal-dev wrote:
>>>> Can you run "gdb autotest/cpp/testclosedondestroydm" , "run" , and
>>>> when it crashed "bt" so we have a backtrace of where it crashes
>>>> (all of that after running "source ../scripts/setdevenv.sh")
>>> It doesn't crash:
>> Ah, the gtest framework must catch the exception. OK, so after
>> starting gdb and before "run", type "catch throw", so that debugger
>> stops when the exception is thrown, and then "bt"
Ok, those that occur in PROJ are expected and not fatal. Go on with
"cont" (you may need to skip another one occurring in
proj_crs_get_coordoperation())
http://www.spatialys.com
