[gdal-dev] GDAL & CAD Files
Robert Coup
robert.coup at koordinates.com
Wed Jun 26 03:15:39 PDT 2024
On Tue, 25 Jun 2024 at 21:11, Michał Kowalczuk via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> First of all, the dwg format is only available in gdal if you buy ODA SDK
> which is very expensive.
There is also an in-house-use license available for ODA
https://www.opendesign.com/pricing/individual
Alternatively, there are a number of tools that do DWG-to-DXF pipeline, and
then as Michal suggested you could then pass the DXF into GDAL. IME it very
much depends on the complexity of the drawings and the autocad features in
use.
Rob :)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240626/33d506d7/attachment-0001.htm>
