[gdal-dev] Detecting SPARSE rasters
    Even Rouault
    even.rouault at spatialys.com
    Fri Jun 28 10:01:06 PDT 2024
Jon,
Recommended solution: use GDALRasterBand::GetDataCoverageStatus() with
nXOff, nYOff, nXSize, nYSize matching tile offset and size and check
forGDAL_DATA_COVERAGE_STATUS_EMPTY. Cf
https://gdal.org/development/rfc/rfc63_sparse_datasets_improvements.html
(undocumented solution, mostly used for internal testing:
rasterBand->GetMetadataItem("BLOCK_SIZE_{block_x_offset}_{block_y_offset}",
"TIFF") where {block_x_offset} / {block_y_offset} must be replaced by
the block index along x and y.If it returns "0", it is a sparse block.)
Even
Le 28/06/2024 à 15:04, Jon Morris via gdal-dev a écrit :
> We usually use the SPARSE_OK option when creating GTiffs, but as a lot
> of our clients use ArcGIS, we need to ensure that the sparse option is
> not used for client deliverables. After a tiff has been created
> though, it’s not easy to tell whether it is sparse or not. Is there an
> easy way of detecting which rasters are sparse and therefore cannot be
> sent to clients?
> Using tiffinfo -D test.tif seems to give an error message like
> “TIFFFillTile: 0: Invalid tile byte count, tile 0.” , so I’ve been
> using this to check, but is there a better way?
> Or have Esri started supporting sparse rasters, and if so, does anyone
> know which version of ArcMap 10.x? (Our clients are mostly on older
> versions, not sure if any are using Pro yet).
> Thanks,
> Jon
> *Jon Morris*
> *Software Developer*
> e:  	Jon.Morris at jbarisk.com
> d: 	+44 (0)1756 587229
> t: 	+44 (0)1756 799919 <tel:+44%20(0)1756%20799919>
> www.jbarisk.com <http://www.jbarisk.com/>
> <https://www.linkedin.com/company/jba-risk-management/>
> <https://twitter.com/JBARisk/>
> <https://www.youtube.com/channel/UC0iatom2jYbW96voW0rlpCw>
> All JBA Risk Management's email messages contain confidential
> information and are intended only for the individual(s) named. If you
> are not the named addressee you should not disseminate, distribute or
> copy this e-mail.
> Please notify the sender immediately by email if you have received
> this email by mistake and delete this email from your system.
> JBA Risk Management Limited is registered in England, company number
> 07732946, 1 Broughton Park, Old Lane North, Broughton, Skipton, North
> Yorkshire, BD23 3FD, England.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240628/18d18801/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240628/18d18801/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240628/18d18801/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240628/18d18801/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240628/18d18801/attachment-0007.png>
