[gdal-dev] Efficient raster bounding box transformation?
Scott
public at postholer.com
Fri May 3 13:41:43 PDT 2024
The bbox is created using the xmin,ymin,xmax,ymax found in the geometry.
Assuming every pixel can be represented as a geometry, that's your bbox.
On 5/3/24 13:18, Simon Eves via gdal-dev wrote:
> Yes, but that's just the corners.
> Consider, say, a raster that contains a satellite sweep which is not
> axis-aligned but forms a "windshield wiper" shape in lon/lat space. The
> bounding box of ALL the pixels is not just the bounding box of the corners.
> On Fri, May 3, 2024 at 1:09 PM Javier Jimenez Shaw <j1 at jimenezshaw.com
> <mailto:j1 at jimenezshaw.com>> wrote:
> Maybe I don't understand your question, but in gdalinfo you have the
> four corners as lat-lon
> On Fri, 3 May 2024, 21:46 Simon Eves via gdal-dev,
> <gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>> wrote:
> So we are trying to optimize our raster import process, and
> particularly the steps to derive the final WGS84/4326 bounding
> box for a raster file or tile thereof.
> Obviously in the general case, the transform is from integer
> pixel coordinate through the Affine Transformation matrix and
> then whatever OGRCoordinateTransformation is required to get to
> WGS84/4326, and perhaps a GCP-based mesh transformation too.
> Currently we are deriving the bounding box by passing all pixels
> of the four edges of the file/tile through the full transform,
> except in the simple Affine-only case where we just transform
> the four corners.
> Is there any shortcut API provided by GDAL or PROJ to allow the
> bounding box to be computed (or at least safely over-estimated)
> in the general case? I'm assuming that even a non-GCP
> OGRCT could still be non-linear such that just transforming the
> corners is insufficient.
> Thanks in advance,
> Simon
> Simon Eves
> Senior Rendering Engineer
> +1 (415) 902-1996
> simon.eves at heavy.ai <mailto:simon.eves at heavy.ai>
> <http://www.heavy.ai>
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
