[gdal-dev] Efficient raster bounding box transformation?
Simon Eves
simon.eves at heavy.ai
Fri May 3 14:25:24 PDT 2024
I like it.
On Fri, May 3, 2024 at 2:24 PM Javier Jimenez Shaw <j1 at jimenezshaw.com>
wrote:
> Now I think I understand what you mean.
> One effective way is to convert the four sides of the image. To avoid the
> conversion of every pixel, you can start a partition process. Then compare
> the difference between the transformed central point and just the mid point
> between the extremes. If that different is bigger than an certain
> threshold, keep subdividing each side. With that you have a good
> approximation of the borders of the image transformed, and then you can
> compute your bounding box.
> The idea is not mine. Even Rouault mentioned it last year in FOSS4G. IIRC,
> it is used by gdalwarp to not reproject every single point; once the
> subdivision is enough, then it does linear interpolation.
> On Fri, 3 May 2024 at 22:18, Simon Eves <simon.eves at heavy.ai> wrote:
>> Yes, but that's just the corners.
>> Consider, say, a raster that contains a satellite sweep which is not
>> axis-aligned but forms a "windshield wiper" shape in lon/lat space. The
>> bounding box of ALL the pixels is not just the bounding box of the corners.
>> On Fri, May 3, 2024 at 1:09 PM Javier Jimenez Shaw <j1 at jimenezshaw.com>
>> wrote:
>>> Maybe I don't understand your question, but in gdalinfo you have the
>>> four corners as lat-lon
>>> On Fri, 3 May 2024, 21:46 Simon Eves via gdal-dev, <
>>> gdal-dev at lists.osgeo.org> wrote:
>>>> So we are trying to optimize our raster import process, and
>>>> particularly the steps to derive the final WGS84/4326 bounding box for a
>>>> raster file or tile thereof.
>>>> Obviously in the general case, the transform is from integer pixel
>>>> coordinate through the Affine Transformation matrix and then whatever
>>>> OGRCoordinateTransformation is required to get to WGS84/4326, and perhaps a
>>>> GCP-based mesh transformation too.
>>>> Currently we are deriving the bounding box by passing all pixels of the
>>>> four edges of the file/tile through the full transform, except in the
>>>> simple Affine-only case where we just transform the four corners.
>>>> Is there any shortcut API provided by GDAL or PROJ to allow the
>>>> bounding box to be computed (or at least safely over-estimated) in
>>>> the general case? I'm assuming that even a non-GCP OGRCT could still be
>>>> non-linear such that just transforming the corners is insufficient.
>>>> Thanks in advance,
>>>> Simon
>>>> Simon Eves
>>>> Senior Rendering Engineer
>>>> +1 (415) 902-1996
>>>> <http://www.heavy.ai>
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240503/3a79e424/attachment.htm>
