[gdal-dev] GDAL 3.9.0 rc2 is available (Re: GDAL 3.9.0 rc1 is available)
Even Rouault even.rouault at spatialys.com
Tue May 7 06:02:41 PDT 2024
I've prepared a RC2 to fix a regression in ogr2ogr workflows from
Shapefile (or other datasources with layer metadata items) to PostGIS.
   https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0rc2.tar.xz
   https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0rc2.tar.gz
   https://download.osgeo.org/gdal/3.9.0/gdal390rc2.zip
https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0rc2.tar.gz
   https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0rc2.zip
Even
Le 06/05/2024 à 15:43, Even Rouault via gdal-dev a écrit :
> Hi,
> I have prepared a GDAL/OGR 3.9.0 release candidate.
> NEWS at:
>   https://github.com/OSGeo/gdal/blob/v3.9.0RC1/NEWS.md
> Pick up an archive among the following ones (by ascending size):
>   https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0rc1.tar.xz
>   https://download.osgeo.org/gdal/3.9.0/gdal-3.9.0rc1.tar.gz
>   https://download.osgeo.org/gdal/3.9.0/gdal390rc1.zip
> A snapshot of the gdalautotest suite is also available :
> https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0rc1.tar.gz
>   https://download.osgeo.org/gdal/3.9.0/gdalautotest-3.9.0rc1.zip
> A snapshot of the documentation is at:
>   https://download.osgeo.org/gdal/3.9.0/gdal390doc.zip
> I'll call for a vote promoting it later this week if no serious
> problems are
> reported before.
> There are no major changes, impacting packaging or integration, since
> beta2, but
> functional bugfixes and enhancements:
> * /vsigs/: fix RmdirRecursive() on an empty directory
> * /vsigs/ UnlinkBatch(): make sure that path config options are
> checked for the
>   deleted files and not '/vsigs/batch/
> * /vsiaz/ UnlinkBatch(): make sure that path config options are
> checked for the
>   deleted files
> * Various fixes in MiramonVector driver
> * Warper: add a NODATA_VALUES_PCT_THRESHOLD option
> * gdal2tiles: add --nodata-values-pct-threshold option
> * support HDF5EOS metadata where the GROUP=GridStructure has an empty sub
>   GROUP=Dimension
> * HDF5: implement GetOffset() and GetScale() for netCDF metadata items
> add_offset
>   and scale_factor
> * TileDB: multidim: prevent infinite recursion when opening an array
> in a group
>   where there are 2 or more 2D+ arrays
> * TileDB: multidim: OpenMDArray(): fix opening an array, member of a
> group,
>   which has no explicit name
> * Fix scripts/gdal-bash-completion.sh
> Best regards,
> Even
http://www.spatialys.com
