[gdal-dev] Doxygen Arguments
Even Rouault
even.rouault at spatialys.com
Thu May 9 09:11:57 PDT 2024
Andrew,
this is now fixed per
https://github.com/OSGeo/gdal/commit/393eee77b40ae16751e4d2c0ad3e53386b22d025
. Doxygen apparently takes the function/method at declaration time, and
not definition time, and we had a number of unnamed parameters in
declarations. (I also struggled with weird things when trying to fix
that locally due not using a too recent Doxygen version. The HTML output
was fine, but once integrated with Sphinx/Breathe, the parameters were
still missing. Updating to Doxygen 1.9.8 as now used by our CI fixed things)
Even
Le 09/05/2024 à 15:20, Andrew Bell via gdal-dev a écrit :
> Hi,
> I'm looking at the documentation for GDALRasterBand::RasterIO and it's
> surprising that the names of the arguments aren't included in the
> function prototype despite them being in the doxygen function
> definition. The arguments are described well below the function
> prototype, making it hard to match things up and you have to assume
> that the order matches.
> Does some doxygen expert know how the argument names could somehow be
> included in the function prototype?
> Web page:
> https://gdal.org/api/gdalrasterband_cpp.html#classGDALRasterBand_1a75d4af97b3436a4e79d9759eedf89af4
> Source: https://fossies.org/linux/gdal/gcore/gdalrasterband.cpp (line 110)
> Andrew Bell
> andrew.bell.ia at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240509/0a9fc600/attachment.htm>
