[gdal-dev] GPKG to PG single transaction, different schemas
Matteo Ghetta
matteo.ghetta at gmail.com
Wed May 15 00:31:18 PDT 2024
Hi Even,
thanks for the reply!
I downloaded the
https://github.com/OSGeo/gdal/blob/master/swig/python/gdal-utils/osgeo_utils/samples/ogr2vrt.py
file and used like:
python3 ogr2vrt.py export_db.gpkg export_db.vrt first_layer second_layer
but I get the following error:
File "/home/matteo/import_export/ogr2vrt.py", line 353, in <module>
sys.exit(main(sys.argv))
File "/home/matteo/import_export/ogr2vrt.py", line 329, in main
if src_fd.GetComment():
AttributeError: 'FieldDefn' object has no attribute 'GetComment'
while with the ogr2vrt file in
/usr/lib/python3/dist-packages/osgeo_utils/samples/ogr2vrt.py it works
nice! Not sure what I'm missing.
So basically the content of the resulting file that I've adapted is:
<OGRVRTLayer name="first_schema.first_layer">
<SrcDataSource relativeToVRT="1"
shared="1">export_db.gpkg</SrcDataSource>
<SrcLayer>first_layer</SrcLayer>
<OGRVRTLayer name="second_schema.second_layer ">
<SrcLayer>second_layer </SrcLayer>
and with ogr2ogr it's working nice in a single transaction!
The vrt file generation is also adding layer metadata, is there a way to
avoid them or should I remove them manually after the file creation?
Cheers and thanks again!
Matteo
