[gdal-dev] Data Type Conversion
Andrew Bell andrew.bell.ia at gmail.com
Mon May 20 08:01:28 PDT 2024
The documentation for GDALRasterBand::RasterIO says that it will convert
data from the source data type to the destination data type. I searched the
source code a bit I'm not sure I located the bit that does this conversion.
I'm trying to understand what happens in this conversion process. Is this a
numeric conversion as would be done with a C/C++ cast or is this conversion
simply add or truncate bytes in order to fit in a destination data type. Or
perhaps something else?
Thanks,
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240520/98b4654f/attachment.htm>
