[gdal-dev] Conda failure in GA
Howard Butler howard at hobu.co
Mon May 20 09:53:53 PDT 2024
> On May 20, 2024, at 11:45 AM, Javier Jimenez Shaw via gdal-dev <gdal-dev at lists.osgeo.org> wrote:
> Hi
> The github actions on a branch I created two days ago is failing in Conda environment, and I do not understand the reason
> https://github.com/jjimenezshaw/gdal/actions/runs/9161579309/job/25186735095#step:8:244
> I think it is not related to my code.
> Does anybody know what is it about?
It looks like the numpy 2.0 update was pushed to the gdal-feedstock https://github.com/conda-forge/gdal-feedstock/pull/939 (looking like  GDAL must also build and test clean against Numpy 2.0 at this point too).
The error is the Conda builder complaining that it can't find Numpy 2.0 because our recipe doesn't use the Numpy 2.0 release candidate channel. I think something is busted by this change to the recipe but I have not had time to investigate it.
Howard
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240520/18f5be81/attachment.htm>
