[gdal-dev] libgeotiff 1.7.2 release candidate
Even Rouault
even.rouault at spatialys.com
Tue May 21 06:28:23 PDT 2024
I've prepared a libgeotiff 1.7.2 release candidate.
https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.1rc2.tar.gz
https://download.osgeo.org/geotiff/libgeotiff/libgeotiff-1.7.1rc2.zip
I'll promote it to final later this week if nothing serious is reported
on it before.
News is:
libgeotiff 1.7.2
* GTIFGetDatumInfoEx(): handle dynamic datums
* CMake: adopt GNUInstallDirs
* CMake: export TIFF as a public dependency
* Add XTIFFClientOpenExt() with re-entrant error callbacks
* listgeo: add a -no_corners option to avoid printing corner
coordinates which might be PROJ version sensitive (refs #81)
* Fix test failures with PROJ 9.1.1 and 9.3
* Remove trailing spaces from many files.
* Localize variables and add const when possible in a number of files
* geo_normalize.c: sprintf --> snprintf
* Add missing includes
* Fix -Werror=calloc-transposed-args with gcc 14
* FindPROJ.cmake: proj_experimental;h -> proj_experimental.h
* CMake: add a BUILD_SHARED_LIBS option, and make it default to ON
* autoconf/CMake: add generation of libgeotiff.pc
* Remove INSTALL and install-sh autoconf-generated files
Even
http://www.spatialys.com
