[gdal-dev] building just the python bindings (cmake)
Greg Troxel gdt at lexort.com
Tue May 21 10:26:48 PDT 2024
I had not gotten to converting the pkgsrc package to cmake, because it
seemed like it would take a long time.  So gdal is at 3.5.3, the last
one that works with autoconf.  Yes, I know that 3.5 was about two years
ago.  It turns out that it is taking hours to do the conversion, and the
good news is that the main "gdal-lib" package is converted.
I also know 3.5 is not current, but I am trying to convert it to cmake
(which presumably works fine, given that 3.6 dropped autoconf), before
updating to newer versions.
I first  tried running cmake in swig/python (in a build dir), but the
generated makefile doesn't really build anything.
I then tried cmake at top level, and tried to run gmake in swig/python
and it seems to be building large amounts of things that are not the
python binding.  Perhaps all of gdal lib and bin.  The install target
indeed installs libgdal and bin/gdalfoo, regular non-python things, vs
the expected python tools.
The README talks about setuptools.  Should I conclude that cmake is a
red herring here, despite the presence of CMakeLists.txt?   And that the
build should just be setuptools in that dir, with no configure stage?
