[gdal-dev] Using simple ogr2ogr line commands from C# code or another language
Oscar Calderon oscarc at hiltonsoftware.com
Thu May 23 14:25:22 PDT 2024
Hello,
I'm trying to execute these commands from my C# code:
ogr2ogr file1.shp file2.shp
ogr2ogr -update -append filex.shp  filey.shp
ogr2ogr -f GPKG -skipfailures -dialect sqlite -nln xxx file_whatever.gpkg file_whatever.shp
ogr2ogr -sql "sql query" file1.gpkg file2.gpkg
Basically, I'm combining two shapefiles in one, converting the combined file to geo package (gpkg) and then executing some sql queries on this gpkg.
To accomplish this, I've been using Process and ProcessStartInfo (executing a command line from my code), but I want to use the API.
Could someone help me to find the proper documentation or explain how this is done?
Thank you
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240523/fe15c960/attachment.htm>
