[gdal-dev] GDAL WMTS get tiles no documentation
Javier Jimenez Shaw
j1 at jimenezshaw.com
Wed May 29 00:40:39 PDT 2024
On Wed, 29 May 2024 at 08:59, Rahkonen Jukka via gdal-dev <
gdal-dev at lists.osgeo.org> wrote:
> Hi,
> When you have a RasterBand from the WMTS data source, it is abstracted
> and you can read the raster data just like from any other data source and
> raster band
> https://gdal.org/tutorials/raster_api_tut.html#reading-raster-data “There
> are a few ways to read raster data, but the most common is via the
> GDALRasterBand::RasterIO() method. This method will automatically take care
> of data type conversion, up/down sampling and windowing.” GDAL knows which
> tiles to read.
> I do not know if the WMTS driver can do parallel tile downloads. If not,
> it is possible to run many RasterIO() at the same time, each reading data
> from a different window like in this rasterio document
> https://rasterio.readthedocs.io/en/latest/topics/concurrency.html.
Jukka, are you sure you can run several RasterIO in parallel (on the same
dataset)? in GDAL GeoTIFF you cannot: the cache may be corrupted. In that
case I open several datasets over the same file. I do not know about WMTS.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta *Michal
> Kowalczuk via gdal-dev
> *Lähetetty:* keskiviikko 29. toukokuuta 2024 9.08
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDAL WMTS get tiles no documentation
> Hi GDAL fellows
> This is my first post on this mailing list, so I'm asking for
> understanding.
> As all we know the purpose of using WMTS over WMS, I'd like to implement
> parallel downloading tiles from service using C API.
> In my opinion GDAL documentation (
> https://gdal.org/drivers/raster/wmts.html) says nothing on this topic.
> I can get capabilities from WMTS, I can open the selected subdataset but
> how to get tiles for given extent? I could not find any information how to
> do it, even in the GDAL tests on github.
> I am kindly asking for tips. It also can be in python. How using pure GDAL
> API fetch tiles to dynamically complete the displayed map. This is my goal.
> Thank you!
> Michal
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240529/0da1c1fd/attachment-0001.htm>
