[gdal-dev] OGR SQL CAST geometry example
Dan Jacobson jidanni at jidanni.org
Thu May 30 16:29:58 PDT 2024
>>>>> "ER" == Even Rouault <even.rouault at spatialys.com> writes:
ER> you can't do operations on geometries with OGR SQL...
OK, I'll try it. Thanks.
The page should still have an example of actual use of
  Casting ... POINT[Z], LINESTRING[Z]
Without examples people will try things like POINTZ, "POINTS[Z]"
