[gdal-dev] gdalwarp across the antimeridian with a source extent >180E
Michael Sumner
mdsumner at gmail.com
Fri May 31 23:19:24 PDT 2024
This data source has an odd georeferencing, it's a 36000x17999 raster in
the extent -179.995 -89.995 180.005 89.995.
vrt://NETCDF:/vsicurl/
https://archive.podaac.earthdata.nasa.gov/podaac-ops-cumulus-protected/MUR-JPL-L4-GLOB-v4.1/20240101090000-JPL-L4_GHRSST-SSTfnd-MUR-GLOB-v02.0-fv04.1.nc:analysed_sst?a_srs=EPSG:4326
(Why is it 17999: well there's one missing row - you'd expect 18000 at 0.01
resolution and that manifests as half a cell short at the top and bottom).
But also the x registration is half a cell to the east from what you would
expect.
It's correctly registered in that frame though, if we shift it west by the
half cell I've verified visually that it "looks wrong" compared to
coastlines etc.
The point of this report is, gdalwarp misses the western window of data for
a request across the antimeridian (there's no data in the output east of
180).
gdalwarp $dsn -te 173.00 -19.85 185.00 -15.00 out1.tif -co COMPRESS=LZW
If we "fix" the extent to be more longitudinally pleasing, we get the data
east of the antimeridian, the map is properly filled either side of the
antimeridian.
https://archive.podaac.earthdata.nasa.gov/podaac-ops-cumulus-protected/MUR-JPL-L4-GLOB-v4.1/20240101090000-JPL-L4_GHRSST-SSTfnd-MUR-GLOB-v02.0-fv04.1.nc:analysed_sst?a_srs=EPSG:4326&a_ullr=-180,89.995,180,-89.995
gdalwarp $dsnfix -te 173.00 -19.85 185.00 -15.00 out2.tif -co COMPRESS=LZW
Which is good, but as mentioned above the workaround means we are now half
a cell out. It works fine for projected windows over the antimeridian in
either situation.
The compressed file sizes reflect the missing data in the second one, these
are 625K and 1.1Mb.
I'd like the warper to be able to correctly fill the data from the western
window in the original case, we have determined that we can't feasibly
"fix" the extent.
Or maybe something else I'm missing? I don't *think* SAMPLE_GRID or
SOURCE_EXTRA helps here. I know that I could craft a meridian-crossing
combination in VRT but I'd rather like this workflow to work as-is.
(Chasing down the weird grid referencing is another project, but it's a
really massive dataset so I'm pretty unconfident of that occurring).
Cheers, Mike
Michael Sumner
Research Software Engineer
Australian Antarctic Division
Hobart, Australia
e-mail: mdsumner at gmail.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20240601/69628397/attachment.htm>
