[gdal-dev] compiling gdal from source for Windows ARM64 failed
Even Rouault even.rouault at spatialys.com
Mon Nov 4 07:48:51 PST 2024
Reiner,
the error "cpl_cpu_features.cpp(69): error C3861: "CPL_CPUID":"
indicates that the compiler goes into a code path that is protected by a
#if defined(HAVE_SSE_AT_COMPILE_TIME).
This HAVE_SSE_AT_COMPILE_TIME macro is set in gdal.cmake when
"${CMAKE_SYSTEM_PROCESSOR}" MATCHES "(x86|AMD64)" .
So I believe there's a misconfiguration of your CMake cross compilation.
Try adding -DCMAKE_SYSTEM_PROCESSOR=ARM64 perhaps. Although
https://cmake.org/cmake/help/latest/variable/CMAKE_SYSTEM_PROCESSOR.html
suggest you should likely rather use a proper CMAKE_TOOLCHAIN_FILE to
set all variables correctly.
Even
Le 04/11/2024 à 16:38, Reiner Schlitzer via gdal-dev a écrit :
> Hi,
> I am trying to compile the GDAL library for the Windows ARM64
> architecture but fail during the build step because of undefined
> CPL_CPUID in the port\cpl_cpu_features.cpp file. The Windows ARM64
> case seems not to be covered in the definition block at the top.
> Can you please give advice on how to fix this issue, or can you please
> get me into contact with people working on creating GDAL binaries for
> Windows ARM64. If GDAL binaries for Windows ARM64 already exist,
> please point me to the download location. Thank you very much in advance.
> Here are details on what I have done:
>   * The GDAL source was downloaded from the master branch at
>     https://github.com/OSGeo/GDAL.
>   * CMAKE configuration command: cmake -DCMAKE_PREFIX_PATH=c:/develop
>     -DBUILD_APPS=OFF -DGDAL_BUILD_OPTIONAL_DRIVERS=OFF
>     -DOGR_BUILD_OPTIONAL_DRIVERS=OFF -DCMAKE_BUILD_TYPE=Release ..
>   * CMAKE build command: cmake --build .
> The output from the config and build steps are attached. Dependencies,
> such as proj, hdf5, netcdf, sqlite3, expat, openssl, zlib and others
> had been compiled successfully previously and are accessible at
> compile time at C:\develop. I am working on a Windows on Arm system
> with Snapdragon(R) X Elite processor and 32GB of RAM.
> Any advice on how to make progress is greatly appreciated. Thanks in
> advance.
> Best regards,
> Reiner Schlitzer
> Prof. Dr. Reiner Schlitzer
> Alfred-Wegener-Institut
> Helmholtz-Zentrum für Polar- und Meeresforschung
> Am Alten Hafen 26
> 27568 Bremerhaven
> GERMANY
> e-mail: Reiner.Schlitzer at awi.de <mailto:Reiner.Schlitzer at awi.de>
> https://www.awi.de/en/about-us/organisation/staff/single-view/reiner-schlitzer.html
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241104/f0175255/attachment.htm>
