[gdal-dev] GPU support for GDAL
Pradeep Mahato
pradeep.cabs at gov.in
Mon Nov 4 23:03:37 PST 2024
I am working on a project with Geo-spatial images using python language. To visualize the images properly pyramid layer is necessary. " buildoverview" functionality of GDAL library in python builds the pyramid(overview) layer utilizing the CPU compute only. As per project requirement , we are dealing with the large volume of the data. For efficient utilization we wanted to use GPU for generating pyramid layer. Does any GDAL library is there which support GPU
सादर धन्यवाद/ Thanks and Regards,
प्रदीप कुमार महतो/ Pradeep Kumar Mahato
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241105/0230805d/attachment.htm>
