[gdal-dev] Request for advice in unexpected slowdown working with LVBAG
Even Rouault
even.rouault at spatialys.com
Sun Nov 10 04:33:38 PST 2024
Jan,
What are those 3.03 and 3.53 versions ? They don't match GDAL official
version numbers. I thought you meant 3.0.3 and 3.5.3, but the LVBAG
driver is new to 3.2.0, so that can't be it. Xerces is *not* a required
DLL for that driver. It uses Expat. Do you use the
AUTOCORRECT_INVALID_DATA=YES open option? If so, the difference could
come from the GEOS version
Even
Le 10/11/2024 à 09:58, Jan Heckman via gdal-dev a écrit :
> My c++ utility-app collects Kadaster BAG data in postgresql tables for
> use in "populatie service".
> It has functioned for several years, with a typical runtime of 40 minutes.
> In the process of rounding this off, I updated the gdal binaries from
> 3.03 to 3.53, as well as added some threaded workloads for analyzing
> the tables.
> Confusingly, the runtime went up to 4 hours and more. This is after
> the download, so internet speed has no role here. It's all local, no
> network and my PC has not degraded. I have tried to reconstruct an
> older setup, but failed to get it back up to speed.
> Profiling and random breaks during waiting point conclusively to the
> function getting features from a layer.
> LVBAG processes lots of xml of a specific (but not highly particular)
> structure.
> My app is compiled, if so indicated, against expat. Xerces is also a
> required dll.
> So my first idea was that there might be a serious performance
> difference between xml libs, but without direct evidence.
> I am using gdal windows binaries from Gisinternals.
> All suggestions are welcome!
> Thanks in advance,
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
