[gdal-dev] conda failing tests in master
Even Rouault
even.rouault at spatialys.com
Sun Nov 10 07:42:28 PST 2024
Le 10/11/2024 à 16:21, Javier Jimenez Shaw via gdal-dev a écrit :
> Just FYI
> I just rebased my master from upstream, and there are failing tests in
> conda
> https://github.com/jjimenezshaw/gdal/actions/runs/11765891451/job/32772764349
yes, this is the same issue as what is blocking the conda-forge 3.10
release (cf
https://lists.osgeo.org/pipermail/gdal-dev/2024-November/059783.html /
https://github.com/conda-forge/gdal-feedstock/pull/992)
> Cheers,
> Javier.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
