[gdal-dev] GDAL, HDF4 and MODIS L1B data
Hernán De Angelis
variablestarlight at gmail.com
Mon Nov 11 04:04:07 PST 2024
Thank you for your response, Jukka.
That is interesting. I set cmake to build hdf4, cmake sees it and it
does not throw errors during the build. In fact, I see:
[ 38%] Built target gdal_HDF4
but the command you gave gives not HDF4
gdalinfo --format hdf4
(should be "formats" instead?)
gdalinfo --formats hdf4
this retrieves a long list, but no HDF5:
gdalinfo --formats | grep hdf
HDF5 -raster,multidimensional raster- (rovs): Hierarchical Data
Format Release 5 (*.h5, *.hdf5)
on the other hand
gdal-config --formats
gives:
MEM vrt HDF4 MEM
So it should be there?
This is confusing. Will keep looking.
Thank you for your time, Jukka!
Hernán
Den 2024-11-11 kl. 12:45, skrev Rahkonen Jukka:
> Hi,
> Have you checked with gdalinfo if you have managed to build the HDF4
> driver?
> Your test file opens for me with GDAL from OSGeo4W.
> -Jukka Rahkonen-
> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
> *Hernán De Angelis via gdal-dev
> *Lähetetty:* maanantai 11. marraskuuta 2024 13.37
> *Vastaanottaja:* gdal-dev at lists.osgeo.org
> *Aihe:* [gdal-dev] GDAL, HDF4 and MODIS L1B data
> I recently compiled a minimal GDAL (3.10) with HDF4 support (using HDF
> 4.3.0) for processing MODIS L1B data. However, the resulting command
> line tools cannot understand the format. Perhaps I am doing something
> wrong, or missing something important, or both.
> Do I understand correctly that MODIS L1B in HDF-EOS format should be
> readable by GDAL compiled with HDF4 support without additional libraries?
> Thanks for any hint.
> Hernán
> Workflow:
> Build HDF4 (4.3.0)
> ./configure --prefix=/home/hernan/project --disable-netcdf
> --disable-fortran --enable-shared --disable-static
> make
> make install
> Build GDAL (3.10) with HDF4 support
> ccmake , make, ... etc
> /home/hernan/project/bin/gdal-config --formats
> MEM vrt HDF4 MEM
> Test
> /home/hernan/project/bin/gdalinfo
> MOD02QKM.A2024307.1325.061.2024308012941.hdf
> ERROR 4: `MOD02QKM.A2024307.1325.061.2024308012941.hdf' not recognized
> as being in a supported file format.
> gdalinfo failed - unable to open
> 'MOD02QKM.A2024307.1325.061.2024308012941.hdf'.
> Testdata if someone wants to try (warning: 150 Mb!):
> https://www.geonatura.se/lastkaj/index.php/s/TCS35pjANsEtSyV
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241111/070c9494/attachment-0001.htm>
