[gdal-dev] GDAL, HDF4 and MODIS L1B data
Hernán De Angelis
variablestarlight at gmail.com
Mon Nov 11 04:37:43 PST 2024
Even,
Thank you for your response. I also suspect there is some mixing going
on. I will have a deeper look at that.
Thank you for your time.
Hernán
BTW the output of the command you suggest is very much like yours:
> grep HDF4 CMakeCache.txt | grep -v INTERNAL | grep -v ADVANCED
//Set ON to build Hierarchical Data Format Release 4 (HDF4) format
GDAL_ENABLE_DRIVER_HDF4:BOOL=ON
//Set ON to build GDAL HDF4 driver as plugin
GDAL_ENABLE_DRIVER_HDF4_PLUGIN:BOOL=OFF
//Set ON to use HDF4
GDAL_USE_HDF4:BOOL=ON
HDF4_INCLUDE_DIR:PATH=/home/hernan/project/include
HDF4_LIBRARY:UNINITIALIZED=/home/hernan/project/lib64/libmfhdf.a
HDF4_df_LIBRARY_DEBUG:FILEPATH=HDF4_df_LIBRARY_DEBUG-NOTFOUND
HDF4_df_LIBRARY_RELEASE:FILEPATH=/home/hernan/project/lib64/libdf.so
HDF4_mfhdf_LIBRARY_DEBUG:FILEPATH=HDF4_mfhdf_LIBRARY_DEBUG-NOTFOUND
HDF4_mfhdf_LIBRARY_RELEASE:FILEPATH=/home/hernan/project/lib64/libmfhdf.so
HDF4_szip_LIBRARY_DEBUG:FILEPATH=HDF4_szip_LIBRARY_DEBUG-NOTFOUND
HDF4_szip_LIBRARY_RELEASE:FILEPATH=HDF4_szip_LIBRARY_RELEASE-NOTFOUND
HDF4_xdr_LIBRARY_DEBUG:FILEPATH=HDF4_xdr_LIBRARY_DEBUG-NOTFOUND
HDF4_xdr_LIBRARY_RELEASE:FILEPATH=HDF4_xdr_LIBRARY_RELEASE-NOTFOUND
//Details about finding HDF4
//MODIFIED property for variable: GDAL_ENABLE_DRIVER_HDF4
//MODIFIED property for variable: GDAL_ENABLE_DRIVER_HDF4_PLUGIN
//Old value of option GDAL_ENABLE_DRIVER_HDF4_PLUGIN
//Test HDF4_HAS_MAXOPENFILES
Den 2024-11-11 kl. 13:29, skrev Even Rouault:
> Hernan,
> this works for me both with HDF4 4.2.14 as available on my system, and
> also against 4.3.0 built from source with the exact configure command
> line your provided
> Can you show the result of "grep HDF4 CMakeCache.txt | grep -v
> INTERNAL | grep -v ADVANCED" in your GDAL build directory?
> For me, looks like that:
> GDAL_ENABLE_DRIVER_HDF4_PLUGIN:BOOL=ON
> HDF4_INCLUDE_DIR:PATH=/home/even/install-hdf4-4.3.0/include
> HDF4_df_LIBRARY_RELEASE:FILEPATH=/home/even/install-hdf4-4.3.0/lib/libdf.so
> HDF4_mfhdf_LIBRARY_RELEASE:FILEPATH=/home/even/install-hdf4-4.3.0/lib/libmfhdf.so
> But I strongly suspect you're running a version of GDAL which is not
> the one you have built. You may have to adjust your PATH and
> LD_LIBRARY_PATH. Check with "which gdalinfo" and then "ldd
> /path/to/gdalinfo" that you are running the binaries you've built.
> "gdalinfo --formats" return the list of drivers, and "gdalinfo
> --format driver_name" return detailed info on the given driver
> Even
> Le 11/11/2024 à 13:04, Hernán De Angelis via gdal-dev a écrit :
>> Thank you for your response, Jukka.
>> That is interesting. I set cmake to build hdf4, cmake sees it and it
>> does not throw errors during the build. In fact, I see:
>> [ 38%] Built target gdal_HDF4
>> but the command you gave gives not HDF4
>> gdalinfo --format hdf4
>> (should be "formats" instead?)
>> gdalinfo --formats hdf4
>> this retrieves a long list, but no HDF5:
>> gdalinfo --formats | grep hdf
>> HDF5 -raster,multidimensional raster- (rovs): Hierarchical Data
>> Format Release 5 (*.h5, *.hdf5)
>> on the other hand
>> gdal-config --formats
>> gives:
>> MEM vrt HDF4 MEM
>> So it should be there?
>> This is confusing. Will keep looking.
>> Thank you for your time, Jukka!
>> Hernán
>> Den 2024-11-11 kl. 12:45, skrev Rahkonen Jukka:
>>> Hi,
>>> Have you checked with gdalinfo if you have managed to build the HDF4
>>> driver?
>>> Your test file opens for me with GDAL from OSGeo4W.
>>> -Jukka Rahkonen-
>>> *Lähettäjä:* gdal-dev <gdal-dev-bounces at lists.osgeo.org> *Puolesta
>>> *Hernán De Angelis via gdal-dev
>>> *Lähetetty:* maanantai 11. marraskuuta 2024 13.37
>>> *Vastaanottaja:* gdal-dev at lists.osgeo.org
>>> *Aihe:* [gdal-dev] GDAL, HDF4 and MODIS L1B data
>>> I recently compiled a minimal GDAL (3.10) with HDF4 support (using
>>> HDF 4.3.0) for processing MODIS L1B data. However, the resulting
>>> command line tools cannot understand the format. Perhaps I am doing
>>> something wrong, or missing something important, or both.
>>> Do I understand correctly that MODIS L1B in HDF-EOS format should be
>>> readable by GDAL compiled with HDF4 support without additional
>>> libraries?
>>> Thanks for any hint.
>>> Hernán
>>> Workflow:
>>> Build HDF4 (4.3.0)
>>> ./configure --prefix=/home/hernan/project --disable-netcdf
>>> --disable-fortran --enable-shared --disable-static
>>> make
>>> make install
>>> Build GDAL (3.10) with HDF4 support
>>> ccmake , make, ... etc
>>> /home/hernan/project/bin/gdal-config --formats
>>> MEM vrt HDF4 MEM
>>> Test
>>> /home/hernan/project/bin/gdalinfo
>>> MOD02QKM.A2024307.1325.061.2024308012941.hdf
>>> ERROR 4: `MOD02QKM.A2024307.1325.061.2024308012941.hdf' not
>>> recognized as being in a supported file format.
>>> gdalinfo failed - unable to open
>>> 'MOD02QKM.A2024307.1325.061.2024308012941.hdf'.
>>> Testdata if someone wants to try (warning: 150 Mb!):
>>> https://www.geonatura.se/lastkaj/index.php/s/TCS35pjANsEtSyV
>> gdal-dev mailing list
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241111/091b5d97/attachment.htm>
