[gdal-dev] Excessive range requests for JP2 files with openjpeg
Even Rouault
even.rouault at spatialys.com
Wed Nov 13 08:47:42 PST 2024
Jérémy,
good point. Adressed per https://github.com/uclouvain/openjpeg/pull/1560
and https://github.com/OSGeo/gdal/pull/11270
Even
Le 13/11/2024 à 15:27, Jérémy Anger via gdal-dev a écrit :
> Hello,
> Trying to optimize the reading speed of JP2 files from object
> storages, I've stumbled upon this PR
> https://github.com/uclouvain/openjpeg/pull/514.
> It introduced a behaviour particularly harmful for network cropping
> JP2 files, as it leads to many excessive requests (time, bandwidth and
> cost wasted).
> As described in the PR, it is possible to disable the fix through the
> compilation flag -DOPJ_DISABLE_TPSOT_FIX=ON.
> Here is a small experiment to compare with and without the fix:
> Setup:
> $ gdalinfo --version
> GDAL 3.9.2, released 2024/08/13
> $ git clone https://github.com/uclouvain/openjpeg --branch v2.5.2
> --depth 1
> $ cd openjpeg
> # build with the fix (default)
> $ mkdir build-enabled-fix && cd build-enabled-fix && cmake ..
> -DCMAKE_BUILD_TYPE=Release -DOPJ_DISABLE_TPSOT_FIX=OFF && make -j && cd ..
> # build without the fix
> $ mkdir build-disabled-fix && cd build-disabled-fix && cmake ..
> -DCMAKE_BUILD_TYPE=Release -DOPJ_DISABLE_TPSOT_FIX=ON && make -j && cd ..
> Benchmark:
> export GDAL_DISABLE_READDIR_ON_OPEN=EMPTY_DIR
> export CPL_CURL_VERBOSE=ON
> # it is possible to tweak CPL_VSIL_CURL_CHUNK_SIZE to reduce the
> number of requests, but this is not studied here
> # this file is composed of 121 tiles of size 1024x1024
> url=/vsicurl/https://storage.googleapis.com/gcp-public-data-sentinel-2/tiles/31/T/CJ/S2B_MSIL1C_20230209T105109_N0509_R051_T31TCJ_20230209T124951.SAFE/GRANULE/L1C_T31TCJ_A030965_20230209T105200/IMG_DATA/T31TCJ_20230209T105109_B02.jp2
> # tile at the beginning
> $ LD_LIBRARY_PATH=$PWD/openjpeg/build-enabled-fix/bin
> gdal_translate -srcwin 0 0 500 500 "$url" o.tif 2>&1 | grep ^Range: |
> wc -l
> 122
> $ LD_LIBRARY_PATH=$PWD/openjpeg/build-disabled-fix/bin
> wc -l
> 2
> # tile in the middle
> gdal_translate -srcwin 5120 5120 500 500 "$url" o.tif 2>&1 | grep
> ^Range: | wc -l
> 122
> ^Range: | wc -l
> 62
> #.tile at the end
> gdal_translate -srcwin 10240 10240 500 500 "$url" o.tif 2>&1 | grep
> ^Range: | wc -l
> 122
> ^Range: | wc -l
> 122
> Note that disabling the fix is particularly important when TLM markers
> are present (on the master branch of openjpeg), but this is not shown
> here. The tests above are from openjpeg v2.5.2 and the Sentinel-2
> rasters do not have TLM markers.
> It might be worth converting the compilation flag into a runtime flag
> on openjpeg's side, and expose it through a GDAL option at least (or
> disabling the fix from GDAL by default).
> What do you think?
> Best regards,
> Jérémy
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
