[gdal-dev] How to generate COG without loosing Exif, XMP etc metadata
Even Rouault even.rouault at spatialys.com
Thu Nov 14 04:02:42 PST 2024
Luigi,
The GDAL GeoTIFF or COG drivers have currently no provision for writing
EXIF (the fact that you see Exif.Image.Software is due to, I assume,
exiftool synthetizing that information from the regular Software TIFF
tag, which is propagated), so I don't have any solution to offer. Could
potentially be implemented, but not a 5-minute job.
"Breaking" the COG structure shouldn't be the end of the world. The
breakage should be minimal. That will just cause one extra HTTP GET to
clients. 95% of the value of COG is just being a tiled GeoTIFF with
overviews. Putting all metadata (including the main TIFF directory) at
beginning of the file is just the cherry on the cake.
(a quick skim at https://github.com/airbusgeo/cogger which is useful to
COGify a tiled GeoTIFF doesn't show any provision for EXIF, so I don't
think you can use it for your use case)
The XMP TIFF tag is propagated:
$ gdal_translate autotest/gdrivers/data/gtiff/byte_with_xmp.tif out.tif
-of cog
$ gdalinfo out.tif -mdd all | grep XMP
Metadata (xml:XMP):
      <rdf:li>XMP</rdf:li>
Even
Le 14/11/2024 à 12:39, Luigi Pirelli via gdal-dev a écrit :
> Hi,
> I'm struggling to generate a COG maintaining the original (or at least
> a selected subset of) Exif and XMP tags (I ses that Iptc tags are not
> propagated at all, but I'm not interested in them).
> I used gda_translate via CLI or python and the best option seems
> -strict that, theoretically should maintain all original tags.
> But some standard tags are propagated and others not!
> e.g.
> Exif.Image.Software yes
> Exif.Photo.CameraOwnerName no
> Exif.Image.Artist yes
> Exif.Image.Copyright yes
> Exif.Image.DateTimeOriginal no
> Exif.Photo.DateTimeOriginal no
> Exif.Image.Model no
> Exif.Image.CameraSerialNumber no
> etc
> It is a bug? a feature? if a bug in any case is there a way to
> override? The reason to find a solution is that adding tags over a COG
> with "standard" tools like exiftool, exiv2 etc destroy COG structure.
> So I need to add or modify tags before converting to COG.
> any suggestion?
> Luigi Pirelli
> mails: luipir at gmail.com
> luigi.pirelli at geobeyond.it
> * LinkedIn: https://www.linkedin.com/in/luigipirelli
> * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
> * GitHub: https://github.com/luipir
> * Book: Mastering QGIS3 - 3rd Edition
> <https://www.packtpub.com/eu/application-development/mastering-geospatial-development-qgis-3x-third-edition>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241114/a6a25822/attachment.htm>
