[gdal-dev] java.sun.com
Even Rouault even.rouault at spatialys.com
Fri Nov 15 04:10:59 PST 2024
the value of the -link argument didn't seem to be used at all, so in
https://github.com/OSGeo/gdal/pull/11281 I just remove it. I suspect
that in the past, there was a link to the base Java doc for base types
(String, etc.), but that no longer seems to work.
Le 15/11/2024 à 10:43, Andrew C Aitchison via gdal-dev a écrit :
> warning: URL http://java.sun.com/javase/6/docs/api/element-list was
> redirected to https://docs.oracle.com/javase/6/docs/api/ -- Update the
> command-line options to suppress this warning.
> Trivial patch attached,
> but Java 6 is a little out of date. Is there a better replacement URL ?
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
