[gdal-dev] Call for review on RFC 104: Adding a "gdal" front-end command line interface
Andrew Bell
andrew.bell.ia at gmail.com
Mon Nov 18 13:27:48 PST 2024
My biggest question is why you would mix vector and raster operations
in the CLI.
And since we're taking on changing things, I would wonder why those
two parts of the codebase are commingled. Is there a strong reason not
to have an OGR project that does vector operations and a GDAL project
that does raster operations? It seems like mostly an historical
artifact.
On Mon, Nov 18, 2024 at 12:58 PM Even Rouault via gdal-dev
<gdal-dev at lists.osgeo.org> wrote:
> Hi,
> Please review https://github.com/OSGeo/gdal/pull/11216 : Adding a "gdal"
> Summary:
> This RFC introduces a single "gdal" front-end command line interface
> (CLI), that exposes sub-commands, adopts a consistent naming of options,
> introduces new capabilities (pipelines) and a concept of algorithms that
> can be
> run through the CLI or that can be automatically discovered and
> invoked programmatically.
> Even
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
> gdal-dev mailing list
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Andrew Bell
