[gdal-dev] Call for review on RFC 104: Adding a "gdal" front-end command line interface
Abel Pau
a.pau at creaf.cat
Tue Nov 19 00:54:32 PST 2024
Good morning,
>> It has just crossed my mind that "gdal convert in.shp out.tif" could do a rasterization behind the scenes, but that's probably pushing syntax sugar too far...
something like "gdal convert in.shp out.gpkg" could be confusing. At least should be an specifier to force vector or raster output, shouldn’t be?
De: gdal-dev <gdal-dev-bounces at lists.osgeo.org> En nombre de Even Rouault via gdal-dev
Enviado el: dilluns, 18 de novembre de 2024 22:44
Para: Andrew Bell <andrew.bell.ia at gmail.com>
CC: gdal-dev at lists.osgeo.org
Asunto: Re: [gdal-dev] Call for review on RFC 104: Adding a "gdal" front-end command line interface
Le 18/11/2024 à 22:27, Andrew Bell a écrit :
My biggest question is why you would mix vector and raster operations
in the CLI.
And since we're taking on changing things, I would wonder why those
two parts of the codebase are commingled. Is there a strong reason not
to have an OGR project that does vector operations and a GDAL project
that does raster operations? It seems like mostly an historical
artifact.
At the beginning of times, GDAL and OGR were separate sub-projects, and it was thought in https://gdal.org/en/latest/development/rfc/rfc46_gdal_ogr_unification.html (almost 10 years ago) that they should be unified, at least as some aspects, driver management, dataset structure and metadata handling, were common between both. Not to mention formats that can contain vector and raster metadata in the same container. Admittedly, some aspects of the unification could still be perfected, like converting a dataset with both types at once. Mostly an implementation detail at the driver level...
In practice there are operations like rasterization, gridding, contouring, polygonization that mix both data types. So considering them as fully separate is not so obvious. I believe that having "gdal convert in.shp out.parquet" and "gdal convert in.tif out.nc" work in an identical way would be big progress compared to "ogr2ogr out.parquet in.shp" and "gdal_translate in.tif out.nc" . It has just crossed my mind that "gdal convert in.shp out.tif" could do a rasterization behind the scenes, but that's probably pushing syntax sugar too far...
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241119/2fc9b323/attachment-0001.htm>
