[gdal-dev] Issue with the STACIT usage examples
Even Rouault
even.rouault at spatialys.com
Thu Nov 21 07:56:00 PST 2024
Jukka,
> Is there something special in the STACIT driver that makes it trickier
> to use than WMS driver?
I don't think so. The STACIT driver uses the same type of string
tokenizer than other drivers that use subdataset syntax. It's weird you
need to escape &. Would the shell be confused by the fact that there's
an escaped double-quote character within the quoted string... ?
At least, just pasting the examples from the documentation page in a
Bash shell works fine.
As an alternative, you can use:
gdalinfo -if STACIT
"https://planetarycomputer.microsoft.com/api/stac/v1/search?collections=naip&bbox=-100,40,-99,41&datetime=2019-01-01T00:00:00Z%2F.."
-oo ASSET=image
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241121/7087e08c/attachment.htm>
