[gdal-dev] Call for review on RFC 104: Adding a "gdal" front-end command line interface
Even Rouault even.rouault at spatialys.com
Mon Nov 25 01:21:43 PST 2024
Hi Rob,
> Is it worth reserving space for a future Git or Github-cli style
> plugin mechanism where third party tools can extend the `gdal` CLI?
> eg: `gdal raster from-contours`
>   * `git foo` simply looks for internal code first, then executes
>     `git-foo` if it's present, then expands any configured command aliases
>   * Github cli has an explicit extension install/packaging mechanism:
>     https://docs.github.com/en/github-cli/github-cli/creating-github-cli-extensions
I would let that aside for now (trying to limit as much as possible the
scope of the current RFC to avoid it going out of control). That's
something that should be relatively easy to add if someone needed that.
But actually you can already extend the "gdal" utility, for commands a
the top level, if you provide a shared library in the gdalplugins
directory and that it registers an algorithm the same way built-in
algorithms do. The bonus point doing that way is that potential GUI
built on top  of gdal that would use "gdal --json-usage" (or the
equivalent C/C++ API) would autodiscover such extension with its
supported options.
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241125/8640d591/attachment.htm>
