[gdal-dev] NULL-returning functions and CPLGetLastErrorMsg
Even Rouault even.rouault at spatialys.com
Wed Nov 27 07:47:57 PST 2024
Laurențiu,
> Many GDAL functions can return nullptr (e.g. OSRGetName,
> OSRGetAuthorityCode etc.), but it's not clear if they set an error
> message that can be retrieved using CPLGetLastErrorMsg. I tried to
> check the code, but CPLErrorSetState isn't called from many places, so
> I'm probably missing something like a PROJ/GEOS error handler that
> sets it.
- OSRGetName() would return null only if the SRS is invalid/unset (you
won't get any CPLError() in that situation). If a unlikely memory
allocation error would occur in PROJ, I believe, but I'm not completely
sure, that PROJ would emit a PROJ error that would be transformed as a
GDAL CE_Failure through the osr_proj_logger() PROJ-error handler
installed in ogr/ogr_proj_p.cpp.
- similarly for OSRGetAuthorityCode(). Returns null on invalid/unset SRS
or SRS without identifier, without emitting a CPLError().   And same as
above if the error occurs within PROJ
> Is there any rule-of-thumb for figuring out when CPLGetLastErrorMsg
> should be used?
No. If you are paranoid about that, reset the error state with
CPLErrorReset() before calling a function and check
CPLGetLastErrorType() == CE_Failure after, but probably only if the
return code of the function is an error. In some circumstances, a
function might return a valid output, but a CE_Failure can be emitted by
deep layers of GDAL but recovered by upper layers that will miss
resetting the error state.
Even
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241127/65e5b59f/attachment.htm>
