[gdal-dev] Should we call RollbackTransaction if CommitTransaction fails?
Even Rouault
even.rouault at spatialys.com
Thu Nov 28 07:19:59 PST 2024
Le 28/11/2024 à 15:10, Laurențiu Nicola via gdal-dev a écrit :
> Hi,
> Is there any advantage in trying to roll back a transaction that
> failed to commit? Will it leave the dataset in a "more usable" state
> than not doing anything?
If you intend to do transactions that may succeed afterwards, you will
need to explicitly RollbackTransaction() to make drivers happy about the
balancing of operations. This is similar to the expected use of BEGIN /
COMMIT / ROLLBACK by SQL engines (at least just tried with PostgreSQL
which requires an explicit ROLLBACK after a failure in a transaction to
recover from it)
> Thanks,
> Laurentiu
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241128/b6cec30d/attachment.htm>
