[gdal-dev] Python API: Geometry.Buffer with JOIN_STYLE
Martin Landa
landa.martin at gmail.com
Fri Oct 4 13:55:21 PDT 2024
Hi all,
in the documentation [1] is mentioned:
Buffer(Geometry self, double distance, char ** options)→ Geometry
where the options argument points to [2]. But
geom.Buffer(6, options=["JOIN_STYLE=MITRE"])
fails with
File "/usr/lib/python3.11/site-packages/osgeo/ogr.py", line 6350, in
Buffer
return _ogr.Geometry_Buffer(self, *args, **kwargs)
TypeError: 'options' is an invalid keyword argument for Geometry_Buffer()
So is there any possibility to use OGR_G_BufferEx's options in the Python
API?
Thanks a lot for your help, Martin
[1] https://gdal.org/en/latest/api/python/vector_api.html#osgeo.ogr.Geometry
[2]
https://gdal.org/en/latest/api/vector_c_api.html#_CPPv414OGR_G_BufferEx12OGRGeometryHd12CSLConstList
Martin Landa
https://geomatics.fsv.cvut.cz/en/employees/martin-landa/
http://gismentors.cz/mentors/landa
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241004/d41c5070/attachment.htm>
