[gdal-dev] writing arrow geometry
Even Rouault
even.rouault at spatialys.com
Mon Oct 7 06:39:37 PDT 2024
Michael,
my understanding of https://geoarrow.org/format.html#memory-layouts is
that what writes OGR is supposed to be fine since they mentionned types
like '|List<List<FixedSizeList<double>[2]>>'|. Perhaps I've missed
something or nanoarrow has stricter expectations? CC'ing Dewey Dunnington
Even
Le 07/10/2024 à 15:23, Michael Sumner via gdal-dev a écrit :
> I realize I left out the INTERLEAVING, ie.
> ogr2ogr ~/fromgdal.arrow
> ogr/data/arrow/from_paleolimbot_geoarrow/polygon-default.ipc -lco
> GEOMETRY_ENCODING=GEOARROW_INTERLEAVED
> but still, I get these list<item elements rather than their
> rings/vertices/geoarrow.point type names:
> <nanoarrow_array_stream struct<row_num: int32, geometry:
> geoarrow.polygon{list<item: list<item: fixed_size_list(2)<xy: double>>>}>>
> On Tue, Oct 8, 2024 at 12:19 AM Michael Sumner <mdsumner at gmail.com> wrote:
> When I investigate the schema in one of the test files
> I see expected list<polygons and list<rings and xy etc. I'm
> printing this by using R nanoarrow::read_arrow, or
> from poLayer->GetArrowStream and I get the same output:
> geoarrow.polygon{list<rings: list<vertices:
> geoarrow.point{fixed_size_list(2)<xy: double>}>>}>>
> If I write a new .arrow with GDAL
> the stream schema looks like this:
> geoarrow.polygon{list<item: list<item: struct<x: double, y:
> double>>>}>>
> and from nanoarrow I see
> nanoarrow::read_nanoarrow("~/fromgdal.arrow")
> Error in read_nanoarrow.character("~/fromgdal.arrow") :
> array_stream->get_schema(): [29] Expected >= 1330795077 bytes of
> remaining data but found 2266 bytes in buffer
> Are we in-between moves regarding specifications, or something?
> I'm having good results generally and this seems like a problem in
> the Arrow driver for write.
> Cheers, Mike
> Michael Sumner
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> Michael Sumner
> Hobart, Australia
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241007/eab01f42/attachment.htm>
