[gdal-dev] writing arrow geometry
Even Rouault even.rouault at spatialys.com
Mon Oct 7 15:37:44 PDT 2024
Joris,
>> The child name of the outer list should be “polygons”; the child name of the middle list should be “rings”; the child name of the inner list should be “vertices”.
Thanks for pointing that out. Should be fixed per
https://github.com/OSGeo/gdal/pull/10962
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241008/cb95c0a1/attachment.htm>
