[gdal-dev] Invalid search_path created in ogrpgdatasource.cpp
Even Rouault
even.rouault at spatialys.com
Wed Oct 9 13:12:39 PDT 2024
Darren,
thanks for the report. I could indeed reproducing setting first an empty
search path (single quote single quote)
alter role {my_user_name} set search_path='';
Fix in https://github.com/OSGeo/gdal/pull/10980
Even
Le 09/10/2024 à 21:18, Boss, Darren WLRS:EX via gdal-dev a écrit :
> I have a Python back-end that uses gdal.Warp to clip a GeoTiff using a
> geometry from a Postgres 14 (with PostGIS) table. I set up the
> gdal.warpOptions and pass them into gdal.warp as follows:
> DB_READ_STRING =
> "postgresql://{read_user}:{postgres_password}@{postgres_read_host}:{postgres_port}/{postgres_database}"
> warp_options = gdal.WarpOptions(format="GTiff",
> cutlineDSName=DB_READ_STRING, cutlineSQL=f"SELECT geom FROM my_table
> WHERE id=1", cropToCutline=True)
> res = gdal.Warp(output_path, my_raster, options=warp_options)
> This has been working great with gdal 3.4 in a K8s cluster running in
> a private cloud using an Ubuntu 20 base image. I’m in the process of
> updating to an Ubuntu 24 LTS image which will be using gdal 3.8.4 and
> running into problems where the table name (my_table) in the
> cutlineSQL can’t be found. The problem seems to be related to the
> search_path and the changes made in this PR:
> https://github.com/OSGeo/gdal/pull/8642
> I turned ON the CPL_DEBUG flag and see the following when trying to
> perform the warp:
> PG: Client encoding: 'UTF8'
> PG: PostGIS schema: 'public'
> PG: Modifying search_path from "" to '',"",'public'
> PG: Command "SET search_path='',"",'public'" failed. Trying without
> 'public'.
> I managed to narrow down the source of the issue and workaround the
> problem but I think there is room for improvement in gdal.
> I narrowed the problem down to ogrpgdatasource.cpp which executes a
> query (SHOW search_path) to retrieve the search_path. In my case the
> search_path being returned was an empty string (or maybe it was a
> string containing a pair of double quotes like ‘””’ or NULL, I’m not
> sure). The code in ogrpgdatasource.cpp would then create a new
> search_path with three comma separated values: ‘’, “”, public. Gdal
> then tries to set this as the search_path and postgres complains about
> the empty string with double quotes.
> SET search_path=‘’,“”,public
> ERROR: zero-length delimited identifier at or near """"
> It looks like the issue stemmed from the fact that the user specified
> in the connection string does not have an associated schema. The
> workaround in my case was to create a matching schema and explicitly
> set the search path for my user to “$user”,public. Simply setting the
> search_path to $user/public for my role or user was insufficient, I
> needed the schema and also had to grant usage on the new schema to the
> appropriate role. Setting the search path on the database was also
> insufficient to resolve the issue. Here’s the debug output now:
> PG: Modifying search_path from "$user", public to '',"$user", public
> So yes, there was likely a configuration issue in my crunchyDB
> cluster, but my question is, would gdal’s creation of an invalid
> search_path with the inclusion of an empty, double quoted string be
> considered a bug from your point-of-view? The empty, single quoted
> string that gdal adds to the search_path also seems odd but doesn’t
> appear to cause any issues.
> I’m happy to create a new issue in GitHub if you feel this is an issue.
> Thanks,
> Darren Boss
> Lead Full Stack Developer, Development & Digital Services
> Water, Land & Resource Stewardship | NRIDS
> Darren.Boss at gov.bc.ca <mailto:Darren.Boss at gov.bc.ca>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241009/88b58775/attachment-0001.htm>
