[gdal-dev] 2D multiband to 3D MULTIDIM results in duplicated "x" dimension
Even Rouault even.rouault at spatialys.com
Mon Oct 14 14:06:14 PDT 2024
Le 14/10/2024 à 22:47, Michael Sumner a écrit :
> Thanks Even!   That makes sense.
> One quibble though, using the netcdf way gives order "Z, y, x",  but
> for Zarr "y, x, Z", is that expected? I can reorder with another step,
> I can't see see a relevant creation option.
That can be controlled with the INTERLEAVE=BAND/PIXEL creation option.
It defaults to the interleave of the source dataset. You want to force
to BAND here
http://www.spatialys.com
Mostly a fool, sometimes acting like a professional (or vice versa)
