[gdal-dev] Zarr v2 and compression problem with small blocks
Even Rouault even.rouault at spatialys.com
Tue Oct 15 03:42:35 PDT 2024
Please file an issue about that
Le 15/10/2024 à 07:39, Michael Sumner via gdal-dev a écrit :
> When I use compression for ZARR_V2 with these small block sizes, I get
> an error:
> gdal_translate
> "/vsicurl/https://github.com/cran/png/blob/master/inst/img/Rlogo.png?raw=true"
> lz4.zarr -of ZARR -co FORMAT=ZARR_V2 -co BLOCKSIZE=4,25,26 -co
> COMPRESS=LZ4  -co INTERLEAVE=BAND
> Input file size is 100, 76
> 0ERROR 1: Decompressed tile lz4.zarr/lz4/0.0.0 has not expected size
> after filters
> It's fine with COMPRESS=NONE, but other compression-on options error
> also.
> With larger block sizes it's seemingly ok
> gdal_translate
> lz4.zarr -of ZARR -co FORMAT=ZARR_V2 -co BLOCKSIZE=4,100,100 -co
> 0...10...20...30...40...50...60...70...80...90...100 - done.
> Is there some kind of minimum on block size, I tried to find a
> combination that gave a clue, it's below 4x100x100, and doesn't seem
> related to single chunk or multiple.
> Cheers, Mike
> Michael Sumner
> Research Software Engineer
> Australian Antarctic Division
> Hobart, Australia
> e-mail: mdsumner at gmail.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Mostly a fool, sometimes acting like a professional (or vice versa)
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241015/b946b8f7/attachment.htm>
