[gdal-dev] gdal_translate
Laurențiu Nicola
lnicola at dend.ro
Tue Oct 15 07:12:51 PDT 2024
Yes, you can use gdal_edit -gcp to add some GCPs, then gdalwarp -tps to straighten out the image.
QGIS has a tool to do this interactively, but last time I tried it, it somewhat buggy and confusing.
Laurentiu
On Tue, Oct 15, 2024, at 16:54, Paul via gdal-dev wrote:
> Is there a way to transform a raster file with selected points other then ulx, uly, lrx and lry in Gdal? I would like to select some distinct pixels in the raster file and connect them to coordinates in my map and then translate.
> Kind regards,
> Paul
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241015/de78bd89/attachment.htm>
