[gdal-dev] ogrmerge running very slow on merging GML to GPGK
Even Rouault
even.rouault at spatialys.com
Sat Oct 19 15:13:17 PDT 2024
Le 20/10/2024 à 00:06, Even Rouault via gdal-dev a écrit :
> Vedran,
> the issue is that your GML files reference a
> http://cap115:8101/geoserver/oss/wfs?service=WFS&version=1.0.0&request=DescribeFeatureType&typeName=oss%3AKATASTARSKE_OPCINE
> XML schema, and if the cap115:8101 server is not reachable, GDAL
> spends some time waiting for it before giving up.
> If all your .gml files share the same schema, you can actually use the
> generated .gfs file (which is a OGR GML specific schema format) for
> all of them, which will skip the step trying to download the XML schema
> Just add " --config GML_GFS_TEMPLATE katastarske_opcine.gfs" (without
> the double quotes) to your ogrmerge command line (cf
> https://gdal.org/en/latest/drivers/vector/gml.html#configuration-options),
> and this should run in one second total.
and to avoid any warning, before running ogrmerge, manually edit
katastarske_opcine.gfs to modify <Width>12</Width> to <Width>15</Width>
> Even
> Le 19/10/2024 à 22:58, Vedran Stojnović via gdal-dev a écrit :
>> Hi all,
>> not sure if this is a bug report so I want to check here if someone
>> has experience with this.
>> I need to merge 98 GML files, each having one MultiLineString feature
>> into one layer so I'm using:
>> ogrmerge -single -f GPKG -o merged.gpkg *.gml
>> But it takes very long time (few seconds per file), and in the
>> meantime gfs files are created every few seconds. I'm running
>> ogrmerge from OSGeo4W Shell on Windows 11 PC, GDAL 3.9.2, released
>> 2024/08/13.
>> My dataset is available here (1 MB ZIP with all 98 files):
>> https://we.tl/t-V8Azs8WokU
>> Kind regards,
>> Vedran Stojnović.
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
> http://www.spatialys.com
> My software is free, but my time generally not.
> Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241020/7e27a7b9/attachment.htm>
