[gdal-dev] Difference between vsis3 support in GDAL and the compile time ENABLE_S3 option for netcdf
Even Rouault even.rouault at spatialys.com
Tue Oct 22 05:32:05 PDT 2024
Two different software / two different implementations.
/vsis3/ support in GDAL applies to *almost* every GDAL supported formats
(all those which declare the DCAP_VIRTUALIO capability). netCDF is in a
weird position. On Linux, thanks to using Linux tricks, it also applies
to netCDF support. On other platforms, we can't. So you might have to
use libnetcdf own mechanism for that
Even
Le 22/10/2024 à 11:39, Parveen Sharma via gdal-dev a écrit :
> Hello
> What the difference is between the generic vsis3 support in GDAL and
> the compile time ENABLE_S3 option for netcdf (and possibly drivers)?
> Best regards,
> Parveen
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
Butcher of all kinds of standards, open or closed formats. At the end, this is just about bytes.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20241022/bd0e3d1b/attachment.htm>
